Date/Time: Fri, 13 Nov 2026 23:16:39 +0000
Trading System Based on Alert Condition - Flatten Option
View Count: 633
| [2023-05-21 16:36:01] |
| User316362 - Posts: 215 |
The Flatten capability added to the study is great and works well. Thanks for adding it. I have a request for another associated check to see if there are working orders when the flatten option is used. For instance adding a Study attribute that says "check for working orders before flattening" option. Or another way of checking for a working order with the study alert formulas etc. The flatten feature helps a lot for multiple uses for me. However, it would be nice for it not to fire if there are no working orders. Thank You. Date Time Of Last Edit: 2023-05-21 16:42:50
