Date/Time: Fri, 13 Nov 2026 23:16:40 +0000
Spreadsheet Study for Trading System does not update from chart
View Count: 636
| [2023-05-20 21:12:44] |
| User522425 - Posts: 16 |
Hi! How can I make the spreadsheet update from the chart? I'm trying to do backtesting and to run sim-trade mode on a spreadsheet algorithm using the Spreadsheet For Trading System Study (not the Alert). The chart will load, but the spreadsheet stays the same and the bid-ask data, for example, does not update (nor does anything else). What can I do? I'd like to be able to run my spreadsheet algorithm and backtest, and then make some money when it works right. |
| [2023-05-22 13:34:56] |
| Sierra_Chart Engineering - Posts: 25424 |
If you do a slow speed replay and not a back test do you notice the spreadsheet Sheet updates? During a back test you may not see updates for performance reasons. This is by design. Otherwise it will unnecessarily slow the back test down. Instructions: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-22 13:35:43
