Date/Time: Fri, 13 Nov 2026 23:16:40 +0000
Can't Activate My Account
View Count: 563
[2023-05-20 20:21:38]
User824963 - Posts: 1
Can you please Activate my account .. every time i try to enter my sms code and i enter it correctly i get this message "Number Not Verified. Please maks sure that you have copied the code correctly from the message sent"
[2023-05-22 13:37:33]
Sierra_Chart Engineering - Posts: 25424
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
