Date/Time: Fri, 13 Nov 2026 23:16:38 +0000
Weekly TPO : Blocks Colors doesn't restart to 1 on new day.
View Count: 598
[2023-05-19 10:17:05]
MattAll - Posts: 1
I'm trying to create a weekly TPO with 14 block colors in each day (30min*14 cash session)
However, instead of coming back to Block Color 1 for the first block on a new day, it continues with color 15, 16, 17, 18.
So, only first day of the week is colored like I want.
My chart session is well corresponding to cash session, no evening, and "Letters Always start At Primary Session Start Time" is set to Yes.
My TPO Letter Sequence is set from A to N
Attached chartbook and sreenshot. Arrows shows Cash Session Open, which should be in green green, the Letter/Block Color 1. (Session opens at 15:30, Paris Hours)
https://www.sierrachart.com/image.php?Image=1684491057302.png
Thank you
attachmentChartbook1.Cht - Attached On 2023-05-19 10:13:42 UTC - Size: 4.16 KB - 377 views
[2023-05-19 20:41:43]
The "Letters Always Start at Primary Session Times" only works with Daily TPOs. The Weekly will not reset at each day.
