Date/Time: Sun, 01 Nov 2026 04:59:10 +0000
Missing CL intraday data
View Count: 1589
| [2014-06-26 22:40:08] |
| User987654 - Posts: 72 |
Hi Support, I am looking at some historical intraday data for CL and it looks like you are missing the file clf11. I know you guys don't have all the historical data but since you have the month before and after, I thought maybe it's just not downloading correctly? Thanks |
| [2014-06-26 23:32:02] |
The data for CLF11 has now been added. Re-download the data in the chart with Edit >>Delete All Data and Download.
| [2014-06-27 03:43:17] |
Thanks for that. It is there now. I am looking at CLG11 and it has lots of spikes in the minute bars. I think it's just bad data, would it be possible for you to reupload the file to see if it can fix the spikes? Thanks |
| [2014-06-27 04:29:36] |
CLG11 has been cleaned up.
