Date/Time: Thu, 08 Oct 2026 02:45:47 +0000
Automated Trading Problem
View Count: 1389
| [2014-06-26 18:01:22] |
| Richard Reyes - Posts: 98 |
I am running an automated trading system using the Excel spreadsheet function. I put "Trade" > "Simulation Fills Source" > "Replay/Back Test Fills" and run my back testing to see how my system performs. I have noticed that once the back testing is complete and I switch from "Replay/Back Test Fills" to "Simulation Fills" all the previous trades that I had using "Replay/Back Test Fills" change dramatically on the chart. Not just change, but drastically change. What is happening? Many Thanks
| [2014-06-26 20:19:07] |
When you change the Simulation Fills Source, you are looking at a completely different set of order fills. If you want to look at the order fills for the back test you need to select Trade >> Simulation Fills Source >> Replay/Back Test Fills. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-26 20:19:19
