Date/Time: Sun, 01 Nov 2026 04:58:57 +0000
Sound alerts request
View Count: 1881
| [2014-06-25 14:45:40] |
| jsoviero - Posts: 84 |
Please offer a few different stock sound alerts. If they already exist please let me know how to enable them. Thank you in advance.
| [2014-06-25 16:23:30] |
You can use whatever alert sounds that you require. You just need to create your own sound wave files. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-06-25 22:42:37] |
Thank you Sierra Support.
Date Time Of Last Edit: 2014-06-26 11:58:07
| [2014-06-26 18:45:21] |
Sound wave files are generally safe to download. In the AlertSounds subfolder you will see 13 sound files listed already. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-27 06:12:46
| [2014-06-27 06:13:11] |
There was a dictation error in the previous post. We meant to say "wave files". It has been corrected.
| [2014-06-27 20:36:28] |
| User13668 - Posts: 296 |
This is a good site for creating free sound files by typing in the text. Can't recall if they are in .wave format, but should be easy to find a free program to convert. http://www2.research.att.com/~ttsweb/tts/demo.php |
