Date/Time: Wed, 25 Nov 2026 21:46:01 +0000
Trade Management by Study with Stop *entry* orders?
View Count: 1305
[2023-05-08 08:53:02]
j4ytr4der_ - Posts: 947
I'm exploring some automation and have run into something I can't find a good solution to. I normally work in spreadsheets but in this case the Trade Management by Study study seems more appropriate.
I want to use a stop *entry* order, and it needs to follow a subgraph until filled. But, the Trade Management by Study study appears to only allow for controlling attached stops on a live position., you can't have it control a stop entry that isn't yet filled.
Is there any way without coding something custom in ACSIL, to manage a stop entry programmatically?
[2023-05-08 09:30:26]
You can modify that study to meet your requirements:
How to Build an Advanced Custom Study from Source Code
[2023-05-08 10:20:31]
Yeah I'm not skilled enough to dive deep into C++. Thanks though.
Date Time Of Last Edit: 2023-05-08 10:21:18
[2023-05-22 10:43:21]
You should be more than skilled enough. This is not difficult. Give it a try. You will see it is not difficult.
[2023-05-22 13:09:28]
OK, I might try it out and see. I can hack code a little bit so with the source provided, maybe I can figure it out. Thanks for the encouragement!
[2025-05-13 17:04:04]
User501309 - Posts: 20
This can be done using a custom study by Frederik at Simple System Trading. The study is called Trade Entry Assistant. https://sst.lemonsqueezy.com/
[2025-05-13 22:58:37]
I recall looking at that and for some reason I can't currently recall, that study didn't do what I needed it to do. But I gave up on the whole pursuit anyway so don't really remember.
