Date/Time: Mon, 05 Oct 2026 01:36:27 +0000
[User Discussion] - Help Programming a Tri-Study Overlay?
View Count: 2280
[2014-06-23 21:19:45]
User20200 - Posts: 38
Hi Guys,
I am needing help on a multiple study program...
I have posted a link below for a sceenshot to review... As you will see there is 2 studies on top of each other. First are the normal studies then a BACKGROUND of COLOR CODED which I want to change color at specific levels as described below...
http://www.sierrachart.com/image.php?l=1403557669399.png
I need the Stochastic overlay to change color when the %D is above (green) or below (Pink) "50" level
I need the RSI overlay to change color when the RSI Line is above (green) or below (Pink) "50" level
I need the MACD overlay to change color when the MACD Line is above (green) or below (Pink) the "0" level
Thank you for your help as always,
Team One
[2014-06-24 12:45:58]
Can anyone help us set these studies up correctly?
Team One
[2014-06-24 14:22:46]
Sawtooth - Posts: 4355
Try this:
Instead of a second instance of each study for the background color, use an instance of the Study Subgraph Subtract study for each background:
-Set the Based On to the relative study
-Set the Chart Region to the same as the relative study
-Set the Input Data to the chosen subgraph
-Set the Amount to Subtract to 50 for the Stochastics and RSI, and 0 for the MACD.
-Set the Draw Style to Background
-Set the Auto-Coloring to Based on +/-
[2014-06-26 22:02:01]
Thanks tomgilb worked great!
One more that I cannot figure out is on the MACD instead of the 0 crossover background color - I would like when the %K & %D crossover to make the background color?
TY
[2014-06-27 02:18:50]
I don't understand this. Please explain.
[2014-06-27 03:26:29]
You said prior to: Study Subgraph Subtract study for each background
Set the Amount to Subtract to 50 for the Stochastics and RSI, and 0 for the MACD... I did...BUT
I wanted to color the background +/- on the crossover of the actual %k & %D line crossing each other, not when the %K line crosses the ZERO line?
Not sure how to set that study correctly...
TY
[2014-06-27 04:09:06]
For this, use the Color Bar Based On Above/Below Study study
-Set the Based On to the Stochastics
-Set the Chart Region to the same as the Stochastics
-Set the Input Data to the %K
-Set the Study Reference to the Stochastics - %D
