Date/Time: Fri, 13 Nov 2026 23:16:42 +0000
# chart trade window settings
View Count: 757
[2023-04-30 00:47:40]
User478380 - Posts: 185
hi
pls see attached
thanks!
Private File
[2023-04-30 17:01:32]
Sierra_Chart Engineering - Posts: 25424
They just become disabled and not removed when you disable those options.
Date Time Of Last Edit: 2023-04-30 17:01:38
[2023-04-30 17:08:28]
hmmmm
fair enough but i dont think thats good coding
its misleading to have an icon there if its disabled
very confusing for the user
[2023-04-30 17:14:18]
you should at least grey out those icons if they are disabled
theres no way to tell whether they are enabled or disabled
[2023-04-30 17:29:39]
They do change color but may be in a way which is not so noticeable. This is controlled by the Windows operating system.
Date Time Of Last Edit: 2023-05-01 03:09:38
[2023-04-30 18:01:58]
so what do i need to do on my end to get them to be greyed out if i disable their function pls ?
thanks
[2023-05-22 10:25:55]
We do not know. This is operating system controlled.
