Date/Time: Sun, 01 Nov 2026 04:59:10 +0000
Rollover Banner
View Count: 1418
| [2014-06-21 14:57:00] |
| wingz - Posts: 121 |
Is there a way to prevent that popup banner from displaying, saying that the symbol needs to rollover,when you go back to a chart for an expired futures symbol?
| [2014-06-28 18:36:25] |
No.
