Date/Time: Fri, 13 Nov 2026 23:16:48 +0000
Sort CW
View Count: 675
| [2023-04-16 13:15:39] |
| inusuel - Posts: 11 |
I go to : Global setting / general setting / *gui / sort cw But when i use menu CW to see all my chart , even if my chart is sort by number , sometime , i can not see the number of the chart . How can i put the number of the chart in CW in the beginning of the line to be sure to see the number of the chart in the menu CW ? |
| Attachment Deleted. |
| [2023-04-16 19:13:10] |
| JohnR - User831573 - Posts: 340 |
One way is to use the Title Bar Name field within the Chart Setting menu , then select the Display tab. There may be other options, but should do what you want. Hope this helps, JohnR |
| [2023-05-20 11:09:11] |
| Sierra_Chart Engineering - Posts: 25424 |
We implemented a new global setting in General Settings >> Charts to control this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-20 11:09:15
