Date/Time: Fri, 26 Apr 2024 17:37:56 +0000
Price holes using spreadsheet study for exporting 5min data
View Count: 838
[2014-06-20 17:01:26] |
Without having any further details, like the symbol and the Data or Trading service you are using, we can only assume that the missing data means the symbol was not trading at the time where you see the missing data. This is all.
