Date/Time: Mon, 16 Nov 2026 23:22:26 +0000
[User Discussion] - Yahoo Data Downloader
View Count: 3537
| [2014-06-14 06:12:38] |
| Kiwi - Posts: 375 |
The following Python code will: - download a base file from your chosen date to the end of this year (stops when the yahoo data stops) (put dates in to suit yourself) - every 5 minutes create the data file you plot by appending the current yahoo data for today to the base file (my files are HSIbase and HSI and my data symbol is ^HSI) Just something you can use or mess around with if you like and want something that Sierra isn't providing currently. It is based on Corey Goldberg's excellent and flexibly general purpose ystockquote. # This is based on:
# # ystockquote : Python module - retrieve stock quote data from Yahoo Finance # # Copyright (c) 2007,2008,2013 Corey Goldberg (cgoldberg@gmail.com) # # license: GNU LGPL # # This library is free software; you can redistribute it and/or # modify it under the terms of the GNU Lesser General Public # License as published by the Free Software Foundation; either # version 2.1 of the License, or (at your option) any later version. # # Requires: Tested under Python 3.4 import time, datetime from urllib.request import Request, urlopen from urllib.parse import urlencode symbol = "^HSI" basedatafile = '/home/john/zRamdisk/SierraChart/Data/HSIbase.dly' datafile = '/home/john/zRamdisk/SierraChart/Data/HSI.dly' startdate = '2007-06-01' enddate = '2014-12-31' seconds_until_repeat = 300 def _request(symbol, stat): url = 'http://finance.yahoo.com/d/quotes.csv?s=%s&f=%s' % (symbol, stat) req = Request(url) resp = urlopen(req) content = resp.read().decode().strip() return content def setup_base(): def get_data(start_date, end_date): """ Get historical prices for the given ticker symbol. Date format is 'YYYY-MM-DD' """ params = urlencode({ 's': symbol, 'a': int(start_date[5:7]) - 1, 'b': int(start_date[8:10]), 'c': int(start_date[0:4]), 'd': int(end_date[5:7]) - 1, 'e': int(end_date[8:10]), 'f': int(end_date[0:4]), 'g': 'd', 'ignore': '.csv', }) url = 'http://ichart.yahoo.com/table.csv?%s' % params req = Request(url) resp = urlopen(req) content = str(resp.read().decode('utf-8').strip()) daily_data = content.splitlines() hist_data = [] for day in daily_data[len(daily_data):0:-1]: dd = day.split(',') hist_data.append([dd[0], dd[1], dd[2], dd[3], dd[4], dd[5]]) return hist_data with open(basedatafile, 'w') as f: ll = get_data(startdate, enddate) for l in ll: f.writelines(", ".join(l) +"\n") def update_day(): with open(datafile, 'w') as f: with open(basedatafile, 'r') as rf: for l in rf: f.writelines(l) t = _request(symbol, 'd1l1om').split(',') y = (datetime.date(int(l[0:4]), int(l[5:7]), int(l[8:10])) + datetime.timedelta(days=1)).isoformat() f.writelines(y + ', ' + t[2] + ', ' + t[3].split('"')[1].split()[2] + ', ' + \ t[3].split('"')[1].split()[0] + ', '+t[1] + ', 0') setup_base() while "lifeonearth": update_day() time.sleep(seconds_until_repeat) print("fell out the bottom") |
| [2016-08-08 03:21:29] |
| Japhro - Posts: 120 |
I have and sometimes use Motivewave software, and it comes with a connection to the Yahoo intraday data service that I believe updates in real time every 1 second. I have checked it against an IB feed and they are essentially the same quotes. It would be interesting to have a live (and free) Yahoo stock data feed for Sierra, similar to the Motivewave setup
