Date/Time: Fri, 13 Nov 2026 20:48:36 +0000
Moving Sierra Chart from old computer to new computer
View Count: 725
| [2023-02-18 18:08:54] |
| denarius - Posts: 17 |
How does one transfer Sierra Charts from one computer to another so that all the charts & chart setups with all the indicators - yours + third party - and with all the preferences / options selected are saved and transferred ? Thank you. |
| [2023-02-18 21:33:41] |
| Sierra_Chart Engineering - Posts: 25422 |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
