Date/Time: Fri, 13 Nov 2026 20:48:26 +0000
Grid lines levels
View Count: 629
[2023-02-17 17:19:10]
BenjFlame - Posts: 353
on an MNQ chart I set "Scale increment" and "Horizontal grid line increment" both to 10.
The text increment are correct: 12340, 12350.... but the grid is not: 12340.50, 12350.50.... I think both should match.
[2023-02-17 17:50:20]
If you have the option for Trade >> Chart DOM Settings >> Other >> Extend Chart Horizontal Grid onto Chart DOM, then the grid will get offset so as not to draw through the numbers. Refer to the information here:
Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
