Date/Time: Fri, 13 Nov 2026 20:48:40 +0000
Can't watch Video's
View Count: 817
[2023-02-17 12:07:38]
58LesPaul - Posts: 429
Using Chrome, Video's will not play and if I click to download I get this?
imageScreenshot_20230217_060532.png / V - Attached On 2023-02-17 12:07:29 UTC - Size: 313.86 KB - 194 views
[2023-02-17 13:48:34]
User90125 - Posts: 715
Looks like you may have VLC on your computer. Retry after deleting and/or reinstalling it.
[2023-02-17 15:23:10]
When you want to download the video you need to right-click on the link and use the command like: Save Link As.
So would be best to download the video and play it in a video player.
Date Time Of Last Edit: 2023-02-17 15:23:51
[2023-02-17 22:11:11]
When I right click and select Save Link As, it saves it as a .txt file.
[2023-02-17 22:15:04]
I don't have VLC on my PC that I can see but what made you think I did?
[2023-02-18 02:32:28]
The first line of the screenshot you posted had something like:
http://www.videolan.org/x264.html
in it.
[2023-02-18 03:49:17]
in it.
Its in my NVidia folder, not sure what I can do to it. I updated the NVidia driver but that didn't help.
