Date/Time: Fri, 13 Nov 2026 20:48:34 +0000
Multiply All Charts study question
View Count: 1134
| [2023-02-17 09:43:57] |
| Nkrastins - Posts: 38 |
Hello, If I understand correctly, that this study: Multiply All Charts will multiply all charts added within the window. So, if I add multiple symbols at the same window, the "Multiple All Charts" study will calculate the medium chart of all added symbols, correct? Also, is possible to make one cumulative delta chart based on all added symbols? |
| [2023-02-17 17:43:48] |
| John - SC Support - Posts: 48527 |
The Multiply All Charts study will multiply all the Main Price Graphs from charts within a Chartbook and put the result in the defined region for the chart on which the study is added. By "medium chart" we assume you are meaning the average. In order to get that, you would have to divide each item in the study (Open/High/Low/Close) by the number of charts that were used to make up the result. To do this, you would have to use the Spreadsheet Formula (Bar) study. Refer to the information here: Spreadsheet Formula In order to make a Cumulative Delta Chart from all the symbols, you would have to add together the data from each symbol. Again, the Spreadsheet Formula (Bar) would be the best choice, but you would first need to use the Study/Price Overlay to get the Cumulative Deltas for each of the symbols into a single chart and then you can add them together. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
