Date/Time: Fri, 13 Nov 2026 20:48:28 +0000
[Programming Help] - Need some function codes of the scsf_CumulativeDeltaBarsTicks Study
View Count: 738
[2023-02-17 04:03:33]
Ragy - Posts: 29
Hello
I am trying to create an indicator based on Cumulative Delta Bars – Trades and I got the source code from scsf_CumulativeDeltaBarsTicks function in the /ACS_Source/studies8.cpp file. However I missing some function codes. Could you please provide me with the code for the following two functions. I could only find their definition but not the code:
SC_ASKBID_NUM_TRADES_DIFF_HIGH
SC_ASKBID_NUM_TRADES_DIFF_LOW
Really appreciate the hep!
Date Time Of Last Edit: 2023-02-17 17:10:03
attachmentIntermediate Study Calculation Functions.txt - Attached On 2023-02-17 17:09:52 UTC - Size: 140.65 KB - 366 views
[2023-02-18 04:51:23]
User90125 - Posts: 715
These are not functions. They are arrays. It doesn't matter how many times you ask, the answer will remain the same.
Programming Help ACSIL | Post: 338228
The code you have access to are custom studies. Most of the rest of Sierra Chart is proprietary code, and that includes how the Max/Min deltas are calculated. Therefore, this is not available.
SC Support has already answered your question....
