Date/Time: Fri, 13 Nov 2026 20:48:33 +0000
Performance Question on Drawing Rectangle Drawing Objects
View Count: 665
[2023-02-16 15:04:18]
Sierra123 - Posts: 33
I am having difficulty determining the performance with simple time tracing within my study, so I'll ask.
My study uses Drawing tools methods to draw a series about 10 rectangles with text in them across the top of a chart. The text represents moving averages, and therefore may change with each invocation of the study.
From a cpu / system resource performance standpoint, which is better, and in rough terms, how much better (e.g. not significant -> very significant)?
a) Create, then Modify each drawing object when text must be changed
b) Create, then Delete and Recreate each drawing object when text must be changed
[2023-02-17 23:17:27]
Would be best to create and modify and specify the position of them by Index instead of Date-Time and make sure they are not user drawn type of drawings.
