Date/Time: Fri, 13 Nov 2026 20:48:33 +0000
Spreadsheet formula efficiency
View Count: 777
| [2023-02-16 13:51:43] |
| User247273 - Posts: 51 |
I realize this might be a dumb question, but is it possible to tell me which of these two formulas below is the most efficient way to get my answer? I have several columns across several sheets with similar types of evaluations so I'm trying to make sure I minimize the demand on my CPU as much as possible. If there's a help page related to this, can you point me in that direction as well. I got a little turned around in my research. Option A: =IF(AND(O3=1,P3=1,Q3=1,R=1,S3=1),1,0) Option B: =IF(SUM(O3:S3)=5,1,0) I'm constructing a spreadsheet system for trading and it looks like I'll need this type of evaluation in about 21000 cells (7 columns * 6 sheets * 500 rows). Even though I'm only evaluating once per bar, I'd like to get the sheets to calculate as fast as possible. |
| [2023-02-16 14:24:20] |
| Sierra_Chart Engineering - Posts: 25422 |
Option A is definitely more efficient.
| [2023-02-18 20:41:37] |
Regarding what is optimal: `AND` or `SUM`. If the values in O3:R3 are in fact boolean values (0 is false and non-zero is true) then the code `=IF(AND(O3=1,P3=1,Q3=1,R=1,S3=1),1,0)` can be optimized further: `=IF(AND(O3,P3,Q3,R3,S3),1,0)` because the `boolean` values are stored as a numerical (double) and can be used interchangable. It reduced computation time by means of ommiting comparison operation (`=`). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-18 20:41:43
