Date/Time: Fri, 13 Nov 2026 20:38:29 +0000
Custom symbol list to open intraday charts quickly
View Count: 680
| [2023-02-14 15:06:20] |
| Attila NN - Posts: 8 |
Dear Sierra! Sorry i was searching for the answer on quite a bit. I would like to have beside my futures list a longer list of nasdaq stocks 60-70 from which i can open intraday chart to chechk the footprint out quickly. What solutions do you reccomend other than memorize all the names? Or is that the quickest if i scan the higher timeframe chart on diffenet platform? thanks in advance |
| [2023-02-14 16:29:51] |
| John - SC Support - Posts: 48527 |
Refer to the information for the Associated Watch List here: Changing the Symbol of a Chart: Using the Associated Watch List For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-02-16 05:59:10] |
This will be amazing! thank you But the watchlist window cant go behind to the unattached chart. but goes behind another one. can the watch list be a normal window comes forward when clicked and goeas behind the chart window of it's? How can i setup this? CAn you recomend a post please |
| Attachment Deleted. |
| [2023-02-16 15:50:02] |
The issue is not related to the Associated Watch List window. It does properly move in front of and behind other windows when other windows get focus. The issue you are having is because the detached window you are using is also set to Always on Top, which then overrides all other windows ability to move in front of that window. Refer to the following: Window, CB and CW Menus: Always on Top (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
