Date/Time: Fri, 13 Nov 2026 20:48:40 +0000
Draw circle on candlebar base on delta
View Count: 832
[2023-02-13 11:53:26]
User129860 - Posts: 33
Hi
Is it possible to draw circle on candle bar base on delta ( possitive and negative ) on each price? ( same as Large volume trade indicator but for delta? )
Thank you!
Regards,
Dolphy
[2023-02-13 16:56:12]
The Large Volume Trade Indicator has options for displaying the Delta data. Refer to the following:
Large Volume Trade Indicator: Inputs
[2023-02-13 21:25:36]
Hi John,
Its only have total delta. Im looking for delta per price level ( tick level ). Is this possible?
[2023-02-13 22:58:36]
Yes, it has it per price level. Under the Input named Draw Mode you have the following options:
- Based on Total Ask Bid Volume Above Threshold - Difference
- Based on Total Ask Bid Volume Above Threshold - Diagonal Difference
The delta option that applies to the entire bar is the following:
- Based on Entire Bar Total Ask Bid Above Threshold - Difference
For more information on how each of these is calculated, refer to the following:
And keep in mind that you can always use a Threshold value of 1, which would give you all the data.
[2023-02-14 02:57:54]
Thanks alot for help John.
Btw, I have another question. It seem like when I add two or more Large volume trade studies. the screen keep flickering or flashing and never stop.
It keep showing up the loading window as the screenshot atttached.
Private File
[2023-02-14 15:31:19]
You can NOT have more than 1 Large Volume Trade Indicator study on a chart. This is covered in the beige highlighted section at the following link:
[2023-02-16 11:06:20]
Hi John,
is there an alternate method? because let say, i want to draw cicle that has certain of bid at the bottom and certain of ask at the high of the candle.? Thank you!
[2023-02-16 17:38:09]
There is not a way to do what you are wanting, at least not on a single chart. You can have the second Large Volume Trade Indicator on another chart and have it set the way you want, but there is not a way to get that information displayed on the first chart.
The reason for this is that the Large Volume Trade Indicator creates its own set of data as the information is read into the system, based on the settings of the study. And then the information for each price level is not available in a subgraph or through any other source.
