Date/Time: Fri, 13 Nov 2026 20:48:21 +0000
Alert True Price
View Count: 751
| [2023-02-12 21:20:48] |
| Ben A - Posts: 123 |
Hi, I have set up an alert and the price for which an alert first comes true is important for my purposes. Is there a way of automatically marking on the chart the first price in which an alert becomes true? Colour by alert condition will alert me to the presence within a bar but not the price at which the alert first occurred. Thanks you for your advice, |
| [2023-02-13 00:48:30] |
| Sierra_Chart Engineering - Posts: 25422 |
No, you can only use this study to color the entire bar: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-13 00:50:07
| [2023-02-18 02:00:02] |
| User61168 - Posts: 491 |
I think Ben can use a combination of "Dash" in Draw Style and "Alert Only Once" checked. This should draw a hyphen on the body of the bar when the first alert condition is triggered. You might have to use "Reset Alert Condition on new bar" as well. (disclaimer: I could be wrong so please try it out)
