Date/Time: Fri, 13 Nov 2026 20:26:12 +0000
Adding exact commission to Trade Activity
View Count: 1598
| [2023-02-09 19:06:03] |
| User525038 - Posts: 14 |
In the Trade Activity Log tables how do you include commissions per lot, in order to obtain a credible result. (original french) Dans le tableaux Trade Activity Log comment faire pour inclure les commissions par lot, de façon a obtenir un résultat crédible. DD |
| [2023-02-09 22:04:18] |
| John - SC Support - Posts: 48527 |
In the Symbol Settings, you can either enter a Global Round Trip Commission Value, refer to the following: Global Symbol Settings: Use Global Round Turn Commission (Global Settings >> Symbol Settings) Or you can enter a per symbol commission within the symbol settings themselves (Round Turn Commission). Refer to the following for how to edit the Symbol Settings: Global Symbol Settings: Instructions Also refer to the following in order to apply the Commissions to the Trade Activity Log: Trade Activity Log: Use Commission For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
