Date/Time: Fri, 13 Nov 2026 20:38:42 +0000
Chart Lag
View Count: 778
[2023-02-09 18:35:35]
Chi Bao - Posts: 11
My TPO chart is lag, price is on top but TPO still on bottom
For example, current price is 4120, but my TPO chart is not loading, just can see the TPO of previous day.
Please see attached and advise, thank you!
(normal candle is not lag, only TPO has issue on my chartbook)
CV
imageLag.PNG / V - Attached On 2023-02-09 18:34:30 UTC - Size: 42.97 KB - 182 views
[2023-02-09 18:44:14]
The date of the most recent TPO in that chart is December 30. Therefore, we have to assume that the chart settings for Data Limiting are set to use Date Range with an ending data of December 30.
Please check your Chart Settings and ensure the chart is setup correctly to display to the current date.
[2023-02-09 19:28:48]
Chi Bao - Posts: 11
Please advise how to load it to current day.
Idk how to do this "Please check your Chart Settings and ensure the chart is setup correctly to display to the current date".
thanks!
[2023-02-09 22:08:30]
Refer to the information for the settings for Chart >> Chart Settings >> Data Limiting which is where you control how many days, or which days, are loaded in a chart:
Chart Settings: Data Limiting
Also refer to the following:
Loading More Or Less Data into an Intraday Chart
