Date/Time: Fri, 13 Nov 2026 19:49:53 +0000
ø
View Count: 483
| [2023-01-23 18:24:11] |
| sgne - Posts: 109 |
ø
Date Time Of Last Edit: 2024-12-05 04:07:29
| [2023-01-24 03:09:00] |
| Sierra_Chart Engineering - Posts: 25422 |
Definitely no: Column H of a spreadsheet trading system: If there's a formula, say, in H55, and the number of spreadsheet data rows is reduced from 53 or higher to 52 or lower, then any user-made H formulas in H55 or below are deleted. But I note that there is no such auto-deletion in columns IJ, below I106/J106. Could you get rid of this auto-deletion for column H? We would have to check on this again but if it exists, this is not going to change. It is therefore a good reason. No, it is definitely much more complex than this: If I understand it correctly, spreadsheet calculation technically begins at cell A3 and goes to the last row in A, then goes to col B, and so forth. If so, then B1 is the cell where a user-made formula would be calculated first, is that correct? It is well beyond the scope of our support to go into this. The calculation order will be correct: Yet the order columns, KLMN, if they depend on formula columns O-Z and any study columns after that, are actually calculated after any study columns in AA, AB, etc. Is that how spreadsheet order calculations actually proceed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-24 03:09:55
