Date/Time: Sat, 17 Oct 2026 13:04:27 +0000
footprint and DOM
View Count: 701
| [2023-01-13 07:44:54] |
| User410956 - Posts: 1 |
hello, how can I get a view of DOM and footprint same as seen on the screenshots attached
Private File Private File |
| [2023-01-13 16:40:29] |
| John - SC Support - Posts: 48239 |
In the screenshot you provided the Footprint and Trading DOM are two different windows that have been placed next to each other. You can do this within the graphics area of Sierra Chart, or you can detach the windows and arrange them on your monitor as you want. Refer to the following regarding detaching windows: Detaching and Attaching Chart Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
