Date/Time: Fri, 13 Nov 2026 20:12:02 +0000
DOM window volume profile is not fully visible
View Count: 638
| [2023-01-12 14:27:20] |
| MatZer0 - Posts: 36 |
Hi I have a DOM window with VBP profile active. Sometimes the profile is not generated or it's not visible. I highlighted example part where the /ES is trading above 3992.75 and that part of the profile section is empty Please see the attached screenshot with both DOM window with part of the profile missing and current configuration visible What do I need to change in the VBP configuration to make it visible for the full range? |
| Attachment Deleted. |
| [2023-01-12 17:03:53] |
| John - SC Support - Posts: 48527 |
You have a study as ID 2 that looks like it is a Study/Price Overlay for a VbP from a ZN chart. But we only see one Volume by Price study on that Trading DOM. You can not use the Study/Price Overlay with the Volume by Price study unless you are overlaying the lines from the VbP. Please remove that second study and see if this resolves your issue.
