Date/Time: Fri, 13 Nov 2026 20:12:04 +0000
Help Order SL and TP
View Count: 1150
| [2023-01-12 10:19:02] |
| User206280 - Posts: 4 |
Can someone help me to set up the order window? I did set a SL and TP, but when the position is open and I move the TP, the SL moves with it, and that wasn't the case at the beginning.
| [2023-01-12 16:07:45] |
| John - SC Support - Posts: 48527 |
Refer to this setting that sounds like the reason you are having the issue you are: Global Trade Settings Windows: Maintain Same Offset Between Target and Stop Attached Orders (Global Settings >> Chart Trade Settings >> General >> Order Modifications) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-12 16:17:41] |
Yes but I mean if a position is open then the SL and TP is set but as soon as I move the SL the TP goes with it and that wasn't at the beginning, how can you undo that this doesn't happen anymore?
| [2023-01-12 16:29:59] |
You need to set this setting to No: Global Trade Settings Windows: Maintain Same Offset Between Target and Stop Attached Orders (Global Settings >> Chart Trade Settings >> General >> Order Modifications) Is it already No? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-13 07:57:50] |
I think I found it, does it fit with the settings?
| Attachment Deleted. |
| [2023-01-13 14:13:38] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes the setting is shown in that Settings Window.
