Date/Time: Sat, 17 Oct 2026 13:04:42 +0000
HIGHLIGHT TPO CHART
View Count: 740
| [2023-01-12 09:24:19] |
| User549422 - Posts: 6 |
Hi, I just want to highlight 'OPEN TPO, only for letter A'. i have try a long time, since results (i can highlight open tpo for all letters, but not only for a choosen letter). if somebody have an answer, it will be apreciate best regards, yann |
| [2023-01-12 16:05:46] |
| John - SC Support - Posts: 48239 |
If you just want to highlight the open of the A TPOs, then this is the Open of the profile. In which case you would set the Input for Highlight Open in Profile to Yes. Refer to the information for this Input at the following link: Time Price Opportunity (TPO) Profile Charts: Highlight Open in Profile If you are looking for something else then we need more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-13 09:24:59] |
thank you for your answer John; i already have this. My letters begin before letter A (klmnoprstvwxyzABCD...) This 'A' is in the center, and i just want the open of this A to be colorate |
| [2023-01-13 17:36:20] |
There is not a way to specifically do that. The only options are the first open of the profile, or all of the opens for each period. It sounds like you had found those options.
