Date/Time: Fri, 13 Nov 2026 20:12:01 +0000
are stops server side with Ironbeam Danali Teton?
View Count: 864
| [2023-01-12 01:04:31] |
| User566779 - Posts: 31 |
| [2023-01-12 04:32:48] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes they are. As long as you are not using a stop order type containing the word "client". Refer to: Order Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-12 04:33:10
