Date/Time: Fri, 13 Nov 2026 20:12:08 +0000
Numbers Bars SHOW ONLY Delta Ask-Bid > X Number?
View Count: 3280
| [2023-01-11 20:51:56] |
| TopGunTrader - Posts: 313 |
Hi, I've spent so much time trying to get ONLY for example 300+ or -300 deltas to show up in text on numbers bars. I want to see significant levels which I can when I have the graph scale to all visible bars however do not want text on 95% of the levels as its completely not needed and is a huge distraction. Is there a setting in Numbers bars to show Detas > 300 absolute value? As you can see on this chart hour+ later market returned to a 300+ positive delta area and bounced almost to the tick. |
| [2023-01-11 22:35:01] |
| John - SC Support - Posts: 48527 |
To do exactly what you want, you would need to set the following: - Text Coloring Method to Based on AskVol/BidVol Difference - Actual - Actual Value Thresholds to 0, 0, 300. - Then change the coloring for the Up/Down Range 0, 1, and 2 levels to be the same as your background and make the Up/Down Range 3 colors what you want. Another option would be to use the Volume at Price Threshold Alert V2 to denote where those levels are. Refer to the following: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-11 22:35:14
| [2023-01-12 11:53:51] |
I can't thank you enough for this! I'm at the point after two years of being slightly and consistently profitable and while I've known about this trade idea for 6-12 months could never implement it correctly until now. I think it will be good for 3-5 more winning trades per day which will allow me more quickly to scale up size from micros to maybe many mini contracts. THANK YOU! I've attached a chart to show what I'm looking for and how often this works. Two to three buy trades yesterday morning near level of a previous large player(s) iceburg buy orders pre market! |
