Date/Time: Fri, 13 Nov 2026 20:12:11 +0000
where do I put my ironbeam trading account number
View Count: 978
| [2023-01-11 16:42:53] |
| User653513 - Posts: 12 |
within Data/Trade settings , i only see space to chose clearing firm. Thanks |
| [2023-01-11 17:33:28] |
| John - SC Support - Posts: 48527 |
If you are using the Teton Order Routing Service, then this is correct. We tie to your account using your Sierra Chart Account Name, which IronBeam will have entered on their end. Refer to the Setup Instructions for the Teton Order Routing Service here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
