Date/Time: Sat, 17 Oct 2026 13:04:43 +0000
Back test accurate mode?
View Count: 5094
| [2023-01-10 20:01:37] |
| Hopeman - Posts: 166 |
I want to ask you a question about the backtest! If you are so kind as to be able to answer as far as possible. I want to ask you a question about the backtest! If you are so kind as to be able to answer as much as possible. I have a Vbp study and an AVD chart overlaid on a center chart as the regression line study is not reflected in the spreadsheet if not used with the study price overlay! I have multiple input conditions with a high volume studio and multiple output conditions, I think overall not much I have the data Tik per tick I am currently doing a playback with exact system bakc test mode and a speed of 480 or lower! I've read the documentation and I think it's all I need to do a replay as fast as possible, Every time the graph reaches the weekend it stops, this is something that happens and it is very cumbersome! On the other hand, I would like to know which baktest system is more reliable since in the documentation I saw that there are several accuratte and tik by tik In the trading window there are three options and every time I do a replay I get a different result? I don't understand that with 4 condition formulas and two studies there is so much room for error king regards Date Time Of Last Edit: 2023-01-13 18:15:38
| [2023-01-13 15:30:38] |
Hello, I'm trying to create an exit condition that takes into account the formula described here in ticks from the same bar or the next one, the problem is that it doesn't read the exit and I don't want to activate more than one entry per bar, I've tried. =(E3<AB5),$J$10/$J$56<-8) and some other variable but I can't find the solution and I don't know if it is possible to exit in the same bar or in the next one if there is a discount in ticks. I've been going around for a couple of days and I can't find the solution. The formula with different conditions is the one attached here. What I'm looking for is that if no condition is met and the price is returned within the VA, if there are less than 8 tiks the ticket it closes, would you be so kind as to help me find the solution, =AND(OR(CROSSFROMBELOW(E3:E5,AC3:AC5),CROSSFROMBELOW(AM3:AM5,AX3:AX5)), OR(CROSSFROMBELOW(AM3:AM5,AX3:AX5),OR(CROSSFROMBELOW(AM3:AM5,AV3:AV5),OR(CROSSFROMBELOW(AM3:AM5,AW3:AW5),OR(CROSSFROMBELOW(E3:E5,AC3:AC5),$J$10/$J$56<-8))))) Best Regards |
| [2023-01-13 18:21:37] |
| Sierra_Chart Engineering - Posts: 25199 |
Every time the graph reaches the weekend it stops, this is something that happens and it is very cumbersome! Replaying Charts: Skip Empty Periods At that time lower the Replay Speed to 1 and then once it is skipped over increase the speed again. On the other hand, I would like to know which baktest system is more reliable since in the documentation I saw that there are several accuratte and tik by tik
In the trading window there are three options and every time I do a replay I get a different result? I don't understand that with 4 condition formulas and two studies there is so much room for error Tick by tick best testing is very slow and impractical. Accurate Trading System Back Test Mode is really what you would want to use. We do not know why there would be a variation. That is very difficult to analyze in each particular case. We can only refer you to: Auto Trade System Back Testing: Consistency Between Back Tests Post #2 question is outside the scope of our support. Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-13 18:22:40
