Date/Time: Fri, 13 Nov 2026 20:12:09 +0000
Copying drawings from chart to ChartDOM
View Count: 892
[2023-01-10 14:11:59]
User513390 - Posts: 49
Dear Friends,
Is is possible to copy Chart Drawings to CHARTDOM?
Thanks for the guidance,
Rodney
[2023-01-10 16:39:53]
It is not possible to copy drawings to a DOM (Chart DOM or Trading DOM).
[2023-01-10 17:53:41]
Dear Support,
It works for the Trading DOM for me.
But not on the Chart DOM.
Can you check, please
Rodney
[2023-01-10 17:59:25]
You can get some drawings on the Trade DOM, if they are for the most recent bars. But the Trading DOM does not really have a concept of a scale in the area to the left of the DOM, which is why we just tried to keep it simple and state that it will not work. There are a lot of contingencies.
We do not understand what you are trying to do with the Chart DOM in terms of drawings. In neither case - Trading DOM or Chart DOM can you get drawings into the actual DOM itself.
But, you can copy drawings between charts without any issue. Refer to the following:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
[2023-01-11 10:44:18]
Just to be clear.
As you said, it's not possible to add Drawing to the Chart DOM on the right in the picture below?
imageCapture d’écran (2).png / V - Attached On 2023-01-11 10:40:48 UTC - Size: 448.77 KB - 340 views
[2023-01-11 16:27:25]
Correct - you can not draw on the DOM area.
