Date/Time: Fri, 13 Nov 2026 20:12:02 +0000
mouse drpdown list
View Count: 651
| [2023-01-05 15:50:37] |
| User427561 - Posts: 217 |
still unable placing hand tool in mouse dop down list can you help?
| [2023-01-05 22:18:25] |
| John - SC Support - Posts: 48527 |
Select Global Settings >> Customize Chart Shortcut Menu. Refer to the attached image for the location of the Hand tool within the list of options. Select it, then select the Add button to move it to the right. Select it on the right and use the Move Up/Move Down to change the location in the list. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-11 20:59:17] |
Thanks John for your continued support
