Date/Time: Fri, 13 Nov 2026 20:12:05 +0000
Drawing a Vol Pro. unable to edit the profile once drawn on the chart.
View Count: 916
[2023-01-05 06:01:10]
User547290 - Posts: 89
I have contacted SC about this in the past, but I am to a point where I need to draw Vol Pro. using the tool rather than the Vol by Price "Study"
I draw the VolPro and there is no way to edit it on my system. I have clicked on every sq in. of the profile and nothing. I have used this tool in the distant past and it worked fine, but now nothing. I have sent you chart-books and they work on your system. but on mine, nothing. unable to edit them.
Any help would be greatly appreciated.
P.S. Tell Ray I said Hi. Maybe he can log on to my computer and see what he thinks when he has a minute.
Douglas Miller
[2023-01-05 18:28:03]
In Tools >> Tool Settings >> General, what are the following two settings set to:
- Select Drawn Volume Profile by Outline Only
- Enable Drawn Volume Profile Selection
[2023-01-07 06:34:21]
That worked. I now can select the Vol Pro. Thanks :) I cant adjust the properties of the drawn VP.
( Chart Drawing Properties is Greyed out. ) I have to open a study and set a profile up and save it, then go to the chart and I can draw a profile. Pain in the butt. Is there a way to activate the Drawing Properties?
[2023-01-09 15:20:34]
You need to right-click on the drawn profile and then select the option for Volume Profile Settings. This will bring up the study settings for the Volume Profile.
[2023-01-12 04:37:57]
I right click on the VolPro and the Volume Profile is greyed out. That's what I'm trying to access. Wondering why it's greyed out. I'm guessing there is a setting somewhere.
imageEpicPen_Ubb5VLLfUL.png / V - Attached On 2023-01-12 04:36:20 UTC - Size: 155.92 KB - 251 views
[2023-01-12 15:33:02]
You need to select the option at the bottom of the list for Volume Profile Settings. Not the Chart Drawing Properties.
[2023-01-12 18:59:15]
Yea, I noticed that last night. Thanks for getting back. Don't know if this is possible but it would be nice to have a save button on the Study Settings window. Were you can "Set Defaults" be able to set the current setting to one of the TC buttons. Thanks again.
