Date/Time: Thu, 19 Nov 2026 13:27:30 +0000
Multiple Symbols to One Chart
View Count: 2431
| [2022-12-27 15:24:04] |
| User585993 - Posts: 83 |
How can I Add Multiple Symbols to One Chart in the same region?
| [2022-12-27 16:34:50] |
| Sierra_Chart Engineering - Posts: 25441 |
There is a study called Add Additional Symbol.: Add Additional Symbol You can add multiple instances of that study and then set each instance to display in the same Chart Region. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-28 16:18:35
| [2024-08-15 17:33:26] |
| VKS19 - Posts: 7 |
If anyone wants to get two charts showing in the same space then you can add the "Additional Symbol Study" In my example below I wanted to have ES and VIX on the same chart, adding the VOLX (VIX) Symbol to the chart and doing the following: - Set the scale to Independant (was automatic) - Change it from bars to Line, go back to Study subgraph, drop down the Graph Draw Type and select Line. - Uncheck set the Subgraph to not "Use Chart Graphics Settings for subgraph" (so you can control the colour of the line - Select the "Last" subgraph node and change the colour. - Apply See image below for how it should look afterwards. Date Time Of Last Edit: 2024-08-15 17:33:55
