Date/Time: Sun, 01 Nov 2026 06:25:29 +0000
Re-Download
View Count: 1551
| [2014-05-29 15:33:48] |
| user5324 - Posts: 10 |
My computer was backed up and then everything was cleared off of it. Sierra charts was put back on it after it was worked on, but now when I try to open Sierra Charts an error message pops up saying it can't be opened because MSVCR100.dll is missing from my computer. I'm not sure what I need to do to correct the error, any help is appreciated.
| [2014-05-29 16:27:37] |
You just need to download and install Sierra Chart again into the same folder where it is located. Download it from here: https://www.sierrachart.com/index.php?l=doc/download.php This will solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-29 16:27:55
