Date/Time: Sun, 01 Nov 2026 06:25:39 +0000
Volume help
View Count: 1392
[2014-05-29 12:56:45]
Rino - Posts: 124
I need help to understand why volume is off. I can understand how
delta could be, but how could volume? (Speaking of ES contract)
I use Infinity for volume and my Sierra charts never matches with what
others have.
The other day for example my DOM showed 37 contracts.
Sierra only showed 16.
Others using Infinity with IRT had 70.
I get package 5 with Sierra and use Numbers bars and Volume profiles.
My volume is always way off compared to others. (light)
Is there something I could do to rectify this? I was considering
using Sierra data but if the charts are the problem why bother?
Please help.
PS Example below
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2691
Charts all had 16
image1V.jpg / V - Attached On 2014-05-29 12:52:25 UTC - Size: 20.08 KB - 674 views
[2014-05-29 12:59:30]
Rino - Posts: 124
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2692
[2014-05-29 16:36:56]
I was considering
You definitely will not have this problem using the Sierra Chart Real-time and Historical Exchange Data Feed.
The other question is whether you are comparing volume for the same time period.
Make sure you have a tick by tick data configuration:
http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php
Refer to help topic 43 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails43.html
Set the chart bars to 1 hour per bar. Let us know what time zone you have set Sierra Chart to. Add the Volume study to the chart and tell us what the volume for a bar is and the starting time of that bar.
Date Time Of Last Edit: 2014-05-29 16:38:31
