Date/Time: Fri, 13 Nov 2026 21:11:13 +0000
Saving/Loading Order Allocation configuration
View Count: 715
| [2022-12-05 11:16:59] |
| ProfitableTrader - Posts: 22 |
Hello, I created and saved my order allocation configuration in a .twconfig for trading MES. When I opened a new DOM for ES for the same account and enable order allocation, the same configuration for MES does not seem to stick. Is allocation configuration specific to the contract traded? And is there a way to load the configuration I saved earlier to my current DOM for a different instrument? Thank you! |
| [2022-12-05 17:57:41] |
| John - SC Support - Posts: 48527 |
The configuration for a Trading Window does not have any effect on the Order Allocation for Trade Accounts. Once you have setup the Order Allocation for Trade Accounts for that particular chart, then it is done for that chart and will not change unless you change the setup directly. Changing the Selected Trading Configuration does not change the order allocation.
