Date/Time: Fri, 13 Nov 2026 21:11:12 +0000
Requesting a New Numbers Bars Calculated Value - Delta Percent Change
View Count: 1819
[2022-12-05 02:34:28]
User708541 - Posts: 213
I went through every option in the Numbers Bars Calculated Values and did not find one that provides the %Change in delta from one bar to the next.
Here are the details of what I'm looking for:
(previous bar's delta - current bar's delta) / current bar's delta, and listed as a percent with options on the number of decimal places. 0 decimal places is fine.
If the bar's deltas were as follows:
-830 -3266 230 -806 -340 797 760 759
The % Change in Delta would be:
-- 293% 107% -450% 58% 334% -5% 0%
[2022-12-05 17:32:06]
You can easily do this yourself. Use the Numbers Bars Calculated Values to get the bar deltas, then use the Spreadsheet Study to perform the calculation you want. You can then display the data in whatever format you want - including "Value of Subgraph" if you want to see the numbers themselves. Refer to the following:
Using the Spreadsheet Study
