Date/Time: Fri, 13 Nov 2026 21:11:10 +0000
[User Discussion] - Working With Differing Monitor Layouts Across Different Machines
View Count: 640
[2022-12-05 01:23:41]
User624595 - Posts: 264
We have a home setup, an office setup, and a travel setup, each with a different monitor configuration.
What is the easiest way to work with the different monitor layouts across all of these, and switch between them?
We could use a specific chartbook for each screen setup, but we use a lot of chartbooks, many instances and it is very cumbersome to update each one.
Is there any easier way to manage the layouts based on the different monitor configurations? What do others do?
Date Time Of Last Edit: 2022-12-05 01:24:19
[2022-12-05 01:43:16]
Also what is the least problematic way to keep the files, chartbooks, settings, Trade Activity logs etc in sync across machines, considering running many instances also, as well as separate installations.
Date Time Of Last Edit: 2022-12-05 03:09:05
