Date/Time: Fri, 13 Nov 2026 21:11:13 +0000
I need access to IB
View Count: 641
| [2022-12-04 20:58:21] |
| User247682 - Posts: 8 |
Hi, I see there is no more interactive brokers in package 5. I read I need to contact you to get accress to. I want to test and see if my study and connection works fine. My renewal time finish in end of april, will it stay same or it will change because of changing packages? Thank you.
Date Time Of Last Edit: 2022-12-04 21:00:41
| [2022-12-04 22:48:54] |
| Sierra_Chart Engineering - Posts: 25422 |
You now have access to Interactive Brokers for the next 30 days at no cost. After that you just need to change the Service Package to 10 or higher: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-04 22:49:06
