Date/Time: Fri, 13 Nov 2026 21:11:21 +0000
[Programming Help] - Using a stock symbol with NQTV vs. Using a stock symbol without NQTV
View Count: 1188
[2022-12-04 17:44:31]
User340098 - Posts: 4
Hi, I have noticed that when I use a stock symbol without NQTV (For Example TSLA) The charts will show more volume data and also the charts on Sierra will be more accurate and match my other charting software (High and low of a candle, volume, ..etc). However, If add NQTV (TSLA-NQTV) then Sierra charts will show less volume and also the chats candles will be little bit different than other charting software that I use. I did a some research on Sierra support and I get kind of conflicting answers. On the video tutorials it is advised that I must use NQTV, but on the Sierra website documents it explained that Stocks Symbols can not be found on the "Find Symbol" in the software and should be added manually. So can you please explain what is the difference between using TSLA or TSLA-NQTV, and which format should I use to get the most accurate data keeping in mind that I am planning to Use TPO with stocks trading.
Thanks,
Omer
[2022-12-05 16:28:33]
At the moment we have two different data feeds for US Stocks. They each have tradeoffs, which is why we still have them both. They are the following:
- Sierra Chart Exchange Data Feed with U.S. Equities exchange. This uses the standard equities symbols (such as TSLA) and has the full consolidated tape information for the volume. But this data does not have market depth data.
- Denali Exchange Data Feed with NASDAQ TotalView exchange. This uses the modified equities symbol with the -NQTV (such as TSLA-NQTV). This data does not have the consolidated tape, so it is only the volume from the NASDAQ that is shown. But it does have the Market Depth data.
Therefore, which one you use depends on what you need. Offhand, if you are using TPOs primarily, and you do not need the Market Depth, then you should use the Sierra Chart Exchange Data Feed.
Note that we are working on getting the consolidated tape for the Denali data feed, but it is still being worked on. When we do have it, then we will switch everyone to the Denali Exchange Data Feed.
To setup the Sierra Chart Exchange Data Feed, follow the instructions at the following link:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
