Date/Time: Fri, 13 Nov 2026 21:11:11 +0000
im not able to load cht file its asking me to contact support
View Count: 732
| [2022-12-03 22:29:37] |
| User315137 - Posts: 2 |
| [2022-12-04 09:34:27] |
| CCTT - Posts: 6 |
Hello, Please read this ! https://www.sierrachart.com/index.php?page=doc/Contents.php Copy this file in data folder in the Sierrachart folder. Thank`s |
| [2022-12-04 19:55:18] |
| Sierra_Chart Engineering - Posts: 25422 |
Instructions to use that Chartbook are here: Chartbooks (Workspaces): Opening Older Chartbooks It is an older format and has to be updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-04 19:55:37
