Date/Time: Fri, 13 Nov 2026 23:16:36 +0000
Crypto
View Count: 1092
| [2022-12-02 16:21:49] |
| User989530 - Posts: 34 |
Hello, what are all the options to trade crypto on Sierra?
| [2022-12-02 18:46:10] |
| John - SC Support - Posts: 48527 |
The only option for trading crypto from Sierra Chart is with Interactive Brokers, which has recently added crypto to their options. Refer to the following: Interactive Brokers Trading Service We do have data for a few different crypto exchanges, but we do not connect to them for trading. Refer to the following: Cryptocurrency / Bitcoin Data and Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-02 20:08:27] |
| Sierra_Chart Engineering - Posts: 25424 |
BitMex is also supported, but it is not a connection that we maintain: BitMEX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
