Date/Time: Fri, 13 Nov 2026 21:24:48 +0000
Scale representation incorrect
View Count: 580
| [2022-12-02 13:07:42] |
| User480109 - Posts: 59 |
Please see the attached file regards to @FVZ22-@FVH23. I have the price display and tick size correct but the on the right scale, it displays a huge interger that should not be there. How do I resolve this?
| [2022-12-02 14:48:36] |
| Sierra_Chart Engineering - Posts: 25422 |
The tick size setting is not correct. You cannot enter it that way. It needs to be entered as an actual floating-point number. For example: 0.5 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
