Date/Time: Fri, 13 Nov 2026 21:11:05 +0000
Where are these settings found in the new versions of SierraChart?
View Count: 852
[2022-12-02 04:40:43]
User14953 - Posts: 268
Chart Settings > Advanced Settings > Display Region Dividing Lines
Chart Settings > Advanced Settings > Settings > Values to Display
Chart Settings > Advanced Settings 2 > Region Data Lines
[2022-12-02 16:46:37]
Chart Settings >> Grid >> Display Region Dividing Lines
Chart Settings >> Display >> Settings [button]
Chart Settings >> Regions >> Region Number x
Note that on the Chart Settings window you have the ability to search for a setting at the top.
[2022-12-03 15:20:31]
We went through the documentation and updated all locations where there still was the use of Advanced Settings.
You should not see this anywhere else at this point in time unless there is use of this on the Support Board in posts.
Date Time Of Last Edit: 2022-12-03 15:21:00
